10 bolt Rear end ID help needed
NO IDEA what this rear end is! There is some numbers stamped below the cover, but that is all I can find. Numbers are 9/99700 and H209. It is 10 bolt, thats all I got. Thanks!!!
Looks like a GM 8.2 or 8.5 to me.
Centerline HotRodsAndHemis.com "Remember, if you didn't put it together with your own hands, its not really yours." - Tim Allen |
8.5" 10-Bolt with Open Carrier. Ratio is stamped on Ring Gear, 41-12 = 3.42 etc...
How wide is it Wheel Mounting surface to WMS? If 58" it's out of a G-Body, wider would be a B-Body. *H209* probably July-20th,89 would be a B-Body. Look on the Axle Tube for code: Location >> http://tech.oldsgmail.com/axle_useage.php http://www.gnttype.org/numbers/axcodes.html Last edited by SSedan64; 12-13-2011 at 04:19 PM. |
Noob questions
Ok, I'll go with that. 8.5 10 bolt Open carrier. Looks like all the material I pulled up on it, thanks a lot! Now, can someone or a group of someones educate me on this rear end? I have no idea if this is a good rear end or not. From what I've read, its good. But I would like some real input, not internet answers. Thanks from the newbie!!!
Unlike the 7.5" and 8.2" 10-Bolt, the 8.5" 10-Bolt is a very strong Rear.
The 8.5" has the same 1.625" diameter Pinion as the 8.875" 12-Bolt. The 8.5" comes stock with 28 & 30-spline Axles & Carriers, 28-spline can be upgraded to 30-spline Carrier & Axles. The 8.5" Ring Gear is only .375" or 3/8" smaller than the 8.875" 12-Bolt Rear. A Girdle Cover is another strength upgrade. http://www.chevyhiperformance.com/te...all/index.html What other Info do you need? Maybe I or someone else can help find it. Todd |
Thanks
Thank you all for the help! Great info, got me on the right track! Thanks!
![]() i'm not sure but it looks like the 7.5" with the fangs in the third pic. Do you have a better view of that area? Do you know what the rear came out of? |
It looks like a Buick Olds Pontiac 10 bolt out of an early A body car. are the axles retained with C clips? it they are its a chevy rear, if not its the BOP. looks identical to the rear in my 67 pontiac tempest. its a decent rear with good aftermarket support.
The date code (H209) will make this a '69 rear end. There should be a code stamped into the axle tube. |
Thanks!!!
You guys are great! I looked up some more stuff after yall pointed me in the right direction. It's a 8.2 bop. It is out of a 69 GTO Tempest Lemans. Thanks!!!
| 12 bolt chevy id help needed | 51chevy283 | Transmission - Rearend | 15 | 04-02-2008 01:16 AM |
| 70's 12 bolt rear to replace 80's 8.5 rear | MRGM | Transmission - Rearend | 4 | 02-07-2008 08:25 PM |
| 10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? | tommytempest | Transmission - Rearend | 14 | 05-09-2007 08:19 PM |
| 8.5 10 Bolt Chevy Info Needed | jsteve068 | Transmission - Rearend | 6 | 09-26-2005 04:09 PM |
| 68 Camaro 12 bolt decode needed | ronnied | Suspension - Brakes - Steering | 6 | 09-08-2005 11:03 AM |
