Thread Tools Search this Thread share on Facebook
  #1
Old 02-11-2012, 09:20 AM
zalooger zalooger is offline
10 bolt rear end, needing brakes
I have a 10 bolt rear end with the following serial numbers:
BP1023C2
Through the novasource site I've figure out some info
BP - 2.73 open (has 4.10)
10 - OCT
23 - Day
C - Buffalo
2 - most likely second shift
brake mounting flange to flange measurement is 54.5". So with the above info it appears to 68-69
I am looking for rear drum brakes. Is it safe to say this rear end is from a 68-69 nova and head to napa or wherever to pick up drum brakes, or is there a chance that is from some other GM car and that year nova brakes won't fit?
Thanks for your help
Register now (free) or login to remove ads
Old 02-11-2012, 03:41 PM
enjenjo enjenjo is online now
Most of the GM cars used the same brakes back in those days. Nova, Chevelle, and Camaro are the same. You do need to know the diameter of the drum, there were some models with bigger brakes. Most had a 9.5" rear brake.
Old 02-11-2012, 04:02 PM
ty for the reply. its going on a 31 roadster so it doesnt need to be exact to any actual car, i just need some rear brakes. i just cant find specifics for 10 bolt rears, so im left with year and model that have the 10 bolt. hoping it is as easy drums for a 68 nova.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "10 bolt rear end, needing brakes"
ThreadThread StarterForumRepliesLast Post
needing tips setting up manual brakes on 95 s10papasmurf812Suspension - Brakes - Steering212-16-2011 03:03 PM
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engincalonIntroduce Yourself201-23-2011 06:52 PM
1994 Camaro 10 Bolt Rear Dics Brakes?TribalTransmission - Rearend201-30-2010 07:42 PM
Switching 71 Camaro 10 Bolt Rear End To Disc BrakesTORI1Suspension - Brakes - Steering104-13-2006 03:38 PM
converting GM 10 bolt to rear disc brakes, have questionsHotRodF100Suspension - Brakes - Steering709-18-2002 11:22 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
