10 bolt rear end on the street - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2006, 09:51 PM
black66's Avatar
www.airriderz.com
Well after I installed my YANK 3800 converter I was finally able to tear my 40 year old rear end apart. Spider gears broke and now it is time for a rebuild.
My six six Impala is street driven 110% of the time. But after the new AFR heads I will be oh so very close to the 500 HP mark, if not slighty passed it.
So with the rebuild I wanted some feedback from those who know about 10 bolt rear ends and what they can handle.
Will my 10 bolt hold up well for street driven car that only sees 2000 miles a year and like to get on it from light to light often.
Stock axles with c clip elimators
Eaton Posi
Richmond 4.10 gear
Or should I spend the extra cash and get Moser's forged axles with c clip elimators instead of the stock axles?
Stock axles are in great shape. Splines have no issues.
I just do not want to get stuff that I do not need because of the "cool" factor.
Thanks for any advice...
Dave
Old 05-17-2006, 06:01 AM
Last journal entry: PICTURE TEST
rear
If your running street radials, and the rear is built correct you should not have any issues... But anything can break!!!!
Keith
Old 05-17-2006, 07:53 AM
I just helped install a 66 Chevrolet big car 12 Bolt into a 70 Impala.
He has a 406 ... about 450 Horsepower and a Turbo 350. The 10 bolt broke a pinion.
Full size car 12 bolts are somewhat easy to come by ... at least around here. They are too wide for the Camaro/Nova guys.
Old 05-18-2006, 10:52 PM
black66's Avatar
www.airriderz.com
rear end
Thanks for the reply guys. I purchased Moser axles. Richmond 4.10 gears. And a posi setup. I will have to wait until thursday of next week to get my axles. But I am excited to go from old 3.73 gears to the new 4.10's. Should be alot of fun on the street...!!!
Dave
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
10 bolt chev rear end beetle9 Transmission - Rearend 3 10-01-2004 04:28 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
Cadillac Seville 10 bolt rear end Larry Day Transmission - Rearend 1 08-09-2003 07:46 AM
