Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 10 bolt rear procedure
Old 10-23-2011, 04:26 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
If it's not making any noise or leaking I'd leave it alone. Not much to replace other than Bearings & Seals. If it has a Posi Carrier that can be rebuilt if needed.
These links are for 12-Bolts but, the 8.5" 10-Bolt is the same except for the Ring Gear diameter.
http://www.webrodder.com/article.php?AID=134&SID=60
http://www.hotrod.com/techarticles/d...install_guide/
