-   -   10 bolt rear procedure (http://www.hotrodders.com/forum/10-bolt-rear-procedure-207493.html)
jd71cam 10-22-2011 05:09 PM
I have a 10 bolt rear I would like to rebuild. I am just wondering what the step by step procedure is . I have the manual . Its out of a 1971 camaro. Just wondering how I can go about getting a schematic or step by step procedure for it, Thanks for your help
SSedan64 10-23-2011 04:26 AM
If it's not making any noise or leaking I'd leave it alone. Not much to replace other than Bearings & Seals. If it has a Posi Carrier that can be rebuilt if needed.
These links are for 12-Bolts but, the 8.5" 10-Bolt is the same except for the Ring Gear diameter.
http://www.webrodder.com/article.php?AID=134&SID=60
http://www.hotrod.com/techarticles/d...install_guide/
