10 bolt rear procedure
I have a 10 bolt rear I would like to rebuild. I am just wondering what the step by step procedure is . I have the manual . Its out of a 1971 camaro. Just wondering how I can go about getting a schematic or step by step procedure for it, Thanks for your help
If it's not making any noise or leaking I'd leave it alone. Not much to replace other than Bearings & Seals. If it has a Posi Carrier that can be rebuilt if needed.
These links are for 12-Bolts but, the 8.5" 10-Bolt is the same except for the Ring Gear diameter. http://www.webrodder.com/article.php?AID=134&SID=60 http://www.hotrod.com/techarticles/d...install_guide/ |
| Procedure to remove rear axles? | HotRodMan | Transmission - Rearend | 4 | 04-16-2010 06:26 PM |
| 70's 12 bolt rear to replace 80's 8.5 rear | MRGM | Transmission - Rearend | 4 | 02-07-2008 08:25 PM |
| 10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? | tommytempest | Transmission - Rearend | 14 | 05-09-2007 08:19 PM |
| Removal procedure of rear main seal | Neophyte | Engine | 2 | 08-26-2004 12:37 AM |
| Rear End - 5 bolt axle shafts into 6 bolt rear axle??? | Blue Chevy | Transmission - Rearend | 0 | 06-07-2002 05:23 PM |
