10 bolt ring gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2005, 06:49 PM
cjg's Avatar
cjg cjg is offline
10 bolt ring gear
i found a 10 bolt and was wondering if it was the 8.5in. ring the numbers on the differential are: 14055251
Old 12-05-2005, 08:53 PM
Here's a pic of an 8.5" rear end center section. Note the projections that the arrows indicate.
Old 12-06-2005, 10:26 PM
10 bolt ring gear
what size socket does the pinion nut take?
If it is a stock gm 8.5 it should use a 1-1/4" socket.
10 bolt ring gear? cjg Transmission - Rearend 2 11-24-2005 12:19 AM
10 bolt vs. 12 bolt. Iwanttolearn Transmission - Rearend 4 02-05-2005 10:32 PM
Rear ends...ring gear..? 67_Deuce Transmission - Rearend 1 01-23-2003 06:58 PM
12 bolt 9.5 ring gear craygunn Transmission - Rearend 2 10-13-2002 02:23 PM
