10 bolt swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2005, 08:45 PM
wayneair's Avatar
slinky+esculator=infinite fun
10 bolt swap
will a '77 camaro 10 bolt posi fit under an '85 monte SS?
Old 11-08-2005, 09:10 PM
adryan16's Avatar
Engine Builder Mentee
Not a standard swap. You'd be better off finding the 7.5" posi that will fit the 3rd Gen G-Body. That rear end will likely be too wide, and I don't think your shock mounts or shackle mounts will line up. I could be way off, but I believe that you'd be better off finding a stock style replacement. On the other hand if you want a bullet proof rear end, I know that there's a company that makes a 9" that will slide right into your G-Body, although the name of the company escapes me as of now. Hope this helps.
Old 11-08-2005, 09:13 PM
wayneair's Avatar
if you remember that company, lemme know. thanks.
Old 11-08-2005, 09:15 PM
adryan16's Avatar
There's always a small advertisement in the back of HotRod magazine for them I believe. If you have one, take a look in the black & white section, and I'm sure you'll see it. I just don't have one near me at the time.
Old 11-08-2005, 10:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If you did not know:
the Camaro diff uses leaf springs. The Monte uses coil springs and control arms to mount the rear diff.
Old 11-11-2005, 04:01 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
And the Camaro axle IS wider from wheel mounting surface to wheel mounting surface, than the G-body axle.
You CAN find a G-body direct fit from Buick Grand National's and a couple other scarce GM models BUT they are very pricey, around $800 for an empty housing.
Currie, Moser, and a couple others make a 9-inch ford housing that will directly bolt in, but they are around $1600 and up empty. One of those axle manufacturers will also make up a GM 12-bolt housing that will directly swap in for around the same cash layout.
73 10 bolt to a 68 chevelle? Sleeve396 Transmission - Rearend 4 08-18-2005 09:23 PM
10 bolt to 12 bolt nick62877 Transmission - Rearend 2 05-04-2005 07:26 PM
GM 8.5", 7.5" 10 bolt ?? and 700R4 ?? williemon Transmission - Rearend 4 12-16-2003 04:11 PM
10 bolt Rear End 71chevelle406 Transmission - Rearend 5 11-10-2003 05:50 PM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 12:22 PM
