yes a posi unit can be installed in the rear, to install it you need a pinion depth guage, a dial indicator and stand, access to a quantity of different thickness shims and spacers and a knowledge of gear patterns. also a lot of patience as you don't know what you have for a pattern till the entire rear is assembled. if it isn't correct you have to pull everything apart and do it again, i've done many of them and have a 15 lb. box of shims, still seems like the one you need you don't have. go to a good trans shop to get your shims the dealerships will look at you like your nuts if you ask them. what size do you need? we'll have one in in two weeks!
