10 vs 12? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2002, 04:49 PM
No Bodies does it better
Post 10 vs 12?
I have a 67 chevelle malibu, but am doing a ss clone project with it. I have a 10 bolt posi traction in the car as is with the standerd 283 engine with th350 trans. Well, the trans is going to be up graded to th400 and am changing the engine to a 454 big block. Now I want to know rear end I should go with 12 bolt or orginal 10?
Old 11-14-2002, 06:22 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Post
Start buildin ya a 12 bolt, but drive the 10 bolt till she goes. It might surprise ya. The 10 bolts are sturdier than ya think. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 11-14-2002, 06:26 PM
Post
If you want to stay with GM get a 12 bolt. Why do you think GM put 12 bolt rearends in vehicles with all their big blocks? Better yet, put in a 9" ford with a spool!!
Old 11-14-2002, 09:43 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
Talking
or you could get wierd and put a Dana 60 in the rear, they have been known to put up with a lot more abuse than a 9in. You're gunna have to get a bigger diff though, the internals of a 10-bolt are not heavy duty enough for that 454
[ November 14, 2002: Message edited by: 78novaman ]</p>
Old 03-29-2004, 04:49 PM
69elcaminoss's Avatar
Actually I have been running an 8.2 10 bolt behind a 454 for a while now. The biggest factor is traction and gear ratio. If I had slicks and a posi turning 4.10 gears, yah, I would probably blow it up. But driving around with 3.08 and an open diff is no problem at all.
Old 03-29-2004, 09:21 PM
Spools aren't really suitable for the street.
Old 03-30-2004, 09:25 PM
My buddy has a 72 firebird with a 455 stroked to a 474 in his car(3400lbs) runs 10.40s all day on a 10 bolt...needless to say I would run the 10 bolt till she blows then upgrade. Just me thought GL to ya!
Old 03-31-2004, 03:35 PM
Chevy Thunder2's Avatar
If your 10 bolt has c-clips I wouldn't use it till it blows, not unless you want to do body work to.
