100 Shot Nitrous - Ring Gap
While gathering parts for my 406 rebuild I have picked up an Edelbrock Performer Nitrous kit along the way, which is adjustable from 50 to 100HP max. Edelbrock indicates this kit can be used on a stock engine without internal modifications.
The rings I am installing are Speed Pro Plasma Moly rings (ductile iron top ring) on hyper pistons and based on the Speed Pro's ring gap guide should be gapped as;
Top Ring - "Nitrous Oxide, Street" application of .005 per inch of bore diameter, which works out to 0.021”
Second Ring - "Nitrous Oxide, Street" application of .006 per inch of bore diameter, which works out to 0.025”
As these are the minimum gaps, I was planning to open them up a bit more to;
Top Ring @ 0.024"
Second Ring @ 0.028"
Are these reasonable gaps to be running for this application (Sunday driver with odd run down the strip) or should I be sticking closer to the N/A gaps defined for "Moderate Performance" being Top Ring .004 / Second Ring .005 per inch of bore diameter.
