$100 for street avenger carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 12:05 AM
would it be worth it?its brand new my dads friend doesnt need it because hes sick with cancer and wants to clean out his garage I have a small block 9:1 ported stock heads 270h comp magnum cam,performer intake I had a performer carb from edelbrock and I dont like it It doesnt perform nearly like the q-jet I took off its a 670cfm
Old 02-14-2008, 03:41 AM
DoubleVision's Avatar
I would have kept the Quadrajet. Any carb is only as good as the guy tuning it. A street avenger is a good carb. but so is the edelbrock. The only advantage the holley has is easier to work on, easier to change jets and etc.
If it were me I would go back to the Quadrajet and leave well enough alone.
Old 02-14-2008, 08:50 AM
If you don't like the Edelbrock and you know the history of the Holley (ie it is as new and little used as the owner says it is) then that seems like a pretty good price to give it a try
Old 02-14-2008, 01:16 PM
302 Z28's Avatar
I have a 670 Street Avenger on my 34, I like it. Idles good and gets fairly good gas mileage. $100 if it's new is a steal.
Vince
Old 02-14-2008, 02:46 PM
malc's Avatar
Living At The Speed Of Life
IŽd take it and store it.
New ones areŽnt going to get cheaper.
Old 02-14-2008, 03:47 PM
I've known this guy since the 80's and he always has his garage well kept he's had this carb in his rollaway and has never opened it.I like the q-jet too especially since that edelbrock cost like $280 and it wouldnt even come close to the qjet and the qjet had problems with it,I had a lot of trouble getting it to idle under 1000 in drive it would lope and die,I changed the carb and it fixed it,but now the truck feels lazy and doesnt move nearly as easy as before I was thinking the holley might bring back some of my performance
Old 02-14-2008, 10:40 PM
the 670 is a good carb i ran one on for a couple years on a pretty hot 327 it had a pretty lean idle transfer that was took a fair amount of tweaking to get right after it was set up right it worked very well for me
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 10:19 PM
backfire thru carb airraptor Engine 11 06-12-2009 03:30 PM
Cleaning Carb Question oldcarguy36 Engine 17 03-04-2006 03:10 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 03:38 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 10:42 AM
