1000 grit scratches - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2006, 12:15 PM
jvsutton's Avatar
Bean Counter
Last journal entry: Paint time
1000 grit scratches
Hey fellas I finnally painted my truck with the John Deere Blitz Black and I was pretty happy with it. But the finish had some rough feeling spots in it and someone on another board suggested wet sanding it, so I did. It is much better now, but I sanded through in some spots (mostly edges) where it was thin. Is it okay to just paint over these spots or should I rough them up some more with the 320 again then paint them. Thanks for the help!
Name:	side black hot rodders.jpg
ID:	12350   Click image for larger version
Name:	desktop black hot rodders.jpg
Old 05-19-2006, 09:43 PM
If you are sanding around the edges of you body lines you should put some tape in those areas so you don't sand them down to bare metal..
Old 05-20-2006, 01:18 AM
black66's Avatar
www.airriderz.com
paint
Did you paint your truck with a paint gun or JD rattle cans?
Dave
Old 05-22-2006, 07:24 AM
jvsutton's Avatar
Bean Counter
I used a cheap conventional type Campbell Hausfeld gun from Wal-Mart, and my 1.5 horsepower 3.7 cfm at 40 psi craftsman compressor. The compressor kept up just fine, it came on but the psi in the tank never dropped below 100 psi while i was painting (according to the gauge on the tank). While I pulled the trigger on the gun I set the regulator to 40 psi. I have to say it turned out way better than any rattle can stuff I have used in the past. Except for the few rough feeling spots I had to sand out. I only have a few spots that I went through while sanding. I'm not going for a great paint job just a decent one.
jvsutton
77 f100
Old 05-22-2006, 01:40 PM
Yeah the paint should go over then 1000 grit scratches just fine, just make sure to use something finer when it's time to buff
Sanding "bondo" with 40 or 36 a No-No! MARTINSR Body - Exterior 44 05-15-2006 09:32 PM
DA scratches when color sanding MrsBondoQueen Body - Exterior 31 10-26-2005 06:41 PM
How can I eliminate sanding scratches jpd37 Body - Exterior 4 06-02-2005 10:35 AM
Can you get out DA scratches from glass? BondoKing Body - Exterior 15 05-06-2005 07:22 PM
What sand paper should be stocked? GMW Body - Exterior 7 10-04-2003 07:32 PM
