#100052 cranecams @.50 216/216 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 09:37 AM
Will a #100052 crane cam work with my 95 silverado tbi350 ;mods:ceramic headers, tbspacer,dual flowmaster 40s
Old 03-03-2012, 10:03 AM
techinspector1's Avatar
Wiki Edits: 326
Let's put some numbers on it so everybody can see what you're asking....
Grind Number: 272 H10
Operating Range: 1600-5400 RPM
Duration Advertised: 272 Intake / 272 Exhaust
Duration @ .050'' Lift: 216 Intake / 216 Exhaust
Valve Lift w/1.5 Rockers: .454'' Intake / .454'' Exhaust
Lobe Separation Angle: 110
Max Lift Angle: 105 ATDC Intake / 115 BTDC Exhaust
Open/Close @.050'' Cam Lift: Intake - 3 BTDC (opens) / 33 ABDC (closes)
Exhaust - 43 BBDC (opens) / (7) BTDC (closes)
This is a flat tappet hydraulic cam. Is your motor flat tappet or roller tappet?
Old 03-03-2012, 10:30 AM
Yes it is a flat tappet block 96 and up is roller
Old 03-03-2012, 12:36 PM
Tech is right to ask. I dunno about ALL the trucks, but there were rollers in 350 Chev motors waaayyyyy before 1996. Just saying'.
PatM
Old 03-03-2012, 01:55 PM
Yea there was roller motors before 96 just not in trucks
Old 03-04-2012, 09:33 PM
tbi or camel humps
also forgot to tell u tech that what heads should i go with i have tbi heads at the moment but i can get some camel humps for cheap but which would be better i know that tbi heads pull low end torque and mid range hp cause i have them on my truck right now with a rv cam but idk how the camel humps work
Cranecams Fireball XR-i points conversion kit question ken47 Electrical 6 10-21-2004 02:24 PM
