That was the msot incredible engine i have ever seen.... It is definetely one of the coolest engines ever...
Jordan |
An engine like that makes me scared to even challenge anyone with my 440 at the stop lights!
Did you guys hear them keep talking about putting one in that guys Chevelle? That would be awesome. Maybe we should start a fund for that engine. What do you guys think? I mean, come on, it's only a $30,000 engine!!! :p
I'm not sure this is the same company because I'm to broke to afford cable, but a few years ago (1997) a company from Long Island NY came out with their V-16 710ci small block the original steel prototype weighed 875lbs produced 725hp and 800ft-lbs with 9:5:1 compression but later made an all aluminum version that was 325 lbs lighter. the companies called High Speed Salvage, 69 windser place, Central Islip, NY, 11722 (516) 348-7070, The adress and phone # is from '97 so I doubt its the same.
When I was in college I worked as an oiler in a coal mine. My job was to keep a P&H dragline cleaned greased and running smoothly. That machine had 2 CAT deasle engines that were as big as an entire yugo. They were V12s and they made 100 HP per cylinder. Once a monthe the oil and filters was changed. 55 gal of motor oil in each crank case.
Now that was an engine! Have no idea what to put it in though.
Ever seen a Locomotive engine, several profiles
V16, turbo, or dual blowers, fuel injected disel each cylinder is complete, piston, cylinder, head,4-valves per cylinder, roller rockers, injector assy,either a master rod or articulating rod,steel crank, external oilpump, waterpump, cooling fans-3-4 each, the motor is 2500 HP it spinns a generater 650,000 volts, trains are really electric. Theres a electric traction motor on each wheel assy.It's a neat consept for a rod, hot motor turns a generator, that gives juice to electric motors each wheel, don't have to work motor so hard for fast times |
bugatti is the car maker you seek for the 1000 engine try this linkhttp://www1.bugatti-cars.de/engl/frameset.html
Most of the motors used in big ships are bunker fired steam turbines, so they are not relevant to this discussion. But I recently was invited on a tour of one of the larger ferry boats that operate daily on puget sound between Seattle and the near shores. These are powered by diesel motors that are three stories high and they have between two and 4 at each end of the boat. All have externally exposed rocker arms which are about 3 feet long each. I think they do about 400 rpm full tilt. They move the ferry boats along pretty well. In fact, when I was in High School, to win $20 I bet some classmates that I could water ski behind one of them... So we stationed a kid on board with about 200 feet of water ski line and a handle. At the appointed time my buddies towed me behind my ski boat along side and then behind the ferry. My friend tossed the ski rope out and I picked up and transferred my weight from the ski boat to the ferry boat. I skiied along for quite a while with the tourists taking pictures until one of the deck hands cut the tow line. That trick would now get you arrested by the Coast Guard or something worse.
