Is the 10066036 4 bolt main from mexico worth building - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2012, 12:24 PM
Hey guys I have a 10066036 4 bolt main I got for free my brother in wants a motor so I thought I would build this for him are they worth building? It had a set of 462624 heads on it and I was wondering how big of a cam I can use without changing the springs and studs at this moment to get his truck cruising down the road I got a good deal on a crane energy cam with a 454 lift will this work with these stock heads I know they are not good heads and prone to cracking but would they last at all til he can buy some better ones
Old 01-04-2012, 03:39 PM
Last journal entry: update
Nothing wrong with those blocks for 400 HP / 6000 RPM.
All 624 heads are suspect, regardless of valve sizes. That cam you found is a mis-match for every version of the 624s. It's single-pattern, which would be fine for the 1.72"-intake-valve-version, except the cam starts working just before the heads are all done. Choose something shorter. If your 624s have 1.94" or 2.02" ( L82 'vette ) intake valves, then you need a dual-pattern cam. Ideally something like the Speed Pro CS1151R, or Comp's DualEnergy 255. If you're not sure what valves are in the heads, then assume 1.94".
Old 01-05-2012, 07:20 AM
ok good deal on the block I figured it would be fine just thought I would check up on it an d on the heads what would be a good set to put on there to work with that cam I work for a company that has a salvage yard so I have quite a few options out there I am wanting to stay away from vortecs also due to the fact I already have valve covers and a manifold so if you have any good ideas I would sure appreciate it thank you
Chevy 350 2 bolt main or 4 bolt main? daledouglas Engine 5 07-21-2011 05:10 PM
2 bolt vs 4 bolt main 350 small block CanadianCory Engine 9 10-30-2005 09:31 PM
2-bolt main vs. 4-bolt main chevy hause Engine 5 10-26-2005 01:37 PM
Is a two-bolt main 454 even worth using? riverdale Engine 13 04-12-2004 08:39 AM
What main cap girdle would you recommend for a chev 400 with a 2 bolt main stonedchihuahua Engine 19 01-05-2003 05:31 AM
