10110810 sbc casting heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2007, 04:43 PM
406 ss monte's Avatar
eat a beaver, save a tree
10110810 & 14101083 sbc heads
10110810 & 14101083. has anyone ever used either these castings? i'm wanting to put a pair on a 305. they have 64cc chambers & 1.94-1.5 valves. their center bolt valve cover head. these would have to be better than a 601 or 416 casting heads. the compression will be 9.12 with the head gaskets & pistons i'm using.
i guess what i'm asking is are they pretty good heads? what do they flow like?
i have not used either of these casting numbers before so any info would be great.
Old 02-04-2007, 04:53 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
From what I've found, it looks like they're swirl port truck heads. It seems that the general consensus on our site is that they're good for low RPM usage, usually nothing much over ~4500 RPM.
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
I Need SBC Heads Suggestions swampwillie Engine 5 08-29-2005 10:32 AM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
185 heads and other missmatched sbc parts capricephil Engine 2 04-12-2004 08:20 PM
sbc heads HotRodS10 Engine 3 06-01-2002 09:16 PM
