Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 11:1 on pump gas or add more gasket??
Old 02-10-2013, 10:28 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
Those heads are adavertised at 64CC chambers and I have seen most heads that the actual CC is higher then advertised,
That is a good size cam and with a 110 lobe sep it will bleed of a dynamic compression which will help.
Max timing should be right at 32 to 34 degrees for What I have seen on the dyno and should be all in ar 2500 RPM.
I think you should be fine.
