-   -   11:1 on pump gas or add more gasket?? (http://www.hotrodders.com/forum/11-1-pump-gas-add-more-gasket-229381.html)
prostcelica 02-09-2013 09:32 PM
Ok guys. I recently picked up a SBC 383. It was to good of a deal to pass up. The motor was completly assemble when I bought it. The guy I bought it from wasn't 100% sure what kind of Compression it was making so I decided it would be a good idea to take it apart and take a few measurements. Know I'm faced with a decision. To get it around 10.5:1 ill have to run a .053 MLS gasket. With the pistons .005 in the hole that is going to put the quench at .058. I guess my questions is would you guys chance 11:1 on 91(I know there is higher octane pump gas out there but I want to be able to buy gas anywhere). Or throw a little more gaksket at it and suffer on the quech a bit??
SBC 350 40 over
Scat 3.75 crank
Eagle 5.7 rods
Speed pro pistons 2 valve reliefs 5cc (.005 thou in the hole)
Edelbrock performer RPM heads 64cc
Comp hydraulic roller 236@50
Performer rpm air gap
750 doble pumper.
prostcelica 02-09-2013 10:01 PM
Oh yeah. I meant to say that its going to be one or the other. I'm going to be using the parts I have. I'm not going to change pistons or buy new heads etc. I'm leaning towords running the thicker gasket. Even with aluminum heads 11:1 is rolling the dice a bit I think.
prumora1 02-09-2013 10:19 PM
if it has aluminum heads on average you will lose one full number on your compress for heat loss. so even though its 11:1 you would be able to run pump gas for 10:1 but retain 11:1 compression performance. so now if you put more gasket in it, it will drop your compression more and the heat retention of the aluminum heads more as well
cobalt327 02-09-2013 10:28 PM
SBC 350 40 over
Scat 3.75 crank
Eagle 5.7 rods
750 doble pumper.
What cam part number or grind?
prostcelica 02-09-2013 10:39 PM
Comp XR288HR part# 08-433-8
cobalt327 02-09-2013 10:59 PM
Keep the quench tight, and run the best premium pump gas you have in your area and you'll be OK.
Listen and look at the plugs carefully for any signs of detonation- just like should be done w/any high performance engine.
This assumes things like the cooling system is adequate, the ignition timing not excessive (you should be able to run max power timing, but do not run anything more than what's absolutely needed), and the fuel/air ratio isn't too lean anywhere in the powerband.
prostcelica 02-10-2013 09:34 AM
Originally Posted by hcompton (Post 1644661)
With 11:1 and a small cam its border line but a little bigger cam should work it out. Lots of ppl use 11:1 in there street cars but careful tuning will be needed.
Is the 11:1 measured or just calculated from what parts you have. The tight quench was probably done to hold back the detonation.
I use this calculator to figure compression. And dynamic compression.
United Engine & Machine Co. Incorporated
The larger quench is not ideal with alum heads and good cam it should be fine. Was the engine knocking before you took it apart?
Also what is the piston volume and type this can be very important.
Fyi: i got 10.8:1 when i ran the numbers. With 6cc pistons and 4.1/.041 gasket.
The compression was calculated by the parts it has in it. I did not fisically measure the stroke or bore. I just pulled the part #'s of the parts. The only thing I measure was the piston to deck clearance.
The motor ran fine but was only ran on a run stand. It has never been installed into a car and been driven in real world conditions.
The pistons are flat top speed pro 2 valve reliefs 5cc
vinniekq2 02-10-2013 09:38 AM
my engine is 10.75:1,I use 94 octane
I have topped up with 91,
I run 34 degrees total,I also have a bigger cam
no problems or indications of any problems
ten years running
prostcelica 02-10-2013 09:39 AM
Thanks for all the input guys. It always much appreciated.
I'm going to ask this question a different way. Out of the to setups below which one is more likley to suffer from detonation. It looks like there is quite a few stations around my area that have 94 so I will go that route.
11:1. With a quench of .045
10.5:1 with a quench of .058
ssmonty 02-10-2013 10:12 AM
5 Attachment(s)
prostcelica,
I know some will say I'm being irresponsible by suggesting something I haven't actually run, but I thought I'd suggest a couple of options you may not have considered, or at least something to think about.
Building a stroker myself, I ran into a problem with what I thought may be too much compression.
I tried to flycut the pistons I had, so that they resembled more of a trough type valve relief to gain some more volume. I checked to see that there was enough material under the location I intended to mill, and it was strictly just my opinion that there was. I first had them flycut straight accross from the back of the exhaust valve relief, but didn't get the volume I thought I wanted, so I had them cut even with the back of the intake valve relief by a different shop(much smoother). Went from 5cc initially to 7cc.
I later realized that I was removing material that would reduce the amount of the squish effect from the close proxcimity between piston and headsurface. Also the pistons had a little too much bore clearance for the 0.030" bores, so I bought some new ones for a .040" overbore.
The new pistons didn't have the same extra material between the 2 valve reliefs on the underside of the piston head that the previous pistons had, so I decided not to flycut them, and to try something else.
I had read about modifing the heads with grooves to suppress detonation. I don't know if they work, but some say they can make a difference between an engine that will run on pump gas, and one that won't. Honestly think that the grooves will fill with carbon to a certain extent, but that the velocity of the squish will keep them from clogging completely, but thats JMHO. They are supposed to creat a jet of mixture that promotes turbulence, thus quicker burn . I think that they also make for a path of flame to get to the far side of the chamber quicker than normal before the far side can detonate from exposure to the heat/pressure of normal combustion.
Like I said, I can't say from experience that they will help in any way whatsoever, but the logic behind them, and testamony of those that have tried them gives me enough courage to give it a shot. Mind you I didn't do it for any increase in power, but just to help the engine live on what I think is too much compression on todays fuel.
By the way I only gained around one cc polishing my chambers.
Also I've heard of more detonation problems by using a thicker gasket to lower CR than a thinner one originally used, but I haven't tried personally.
Like I said, just some things to think about FWIW.
ssmonty
CNC BLOCKS NE 02-10-2013 10:28 AM
Those heads are adavertised at 64CC chambers and I have seen most heads that the actual CC is higher then advertised,
That is a good size cam and with a 110 lobe sep it will bleed of a dynamic compression which will help.
Max timing should be right at 32 to 34 degrees for What I have seen on the dyno and should be all in ar 2500 RPM.
I think you should be fine.
Landshark928 02-10-2013 01:06 PM
I am running 11:1 with aluminium heads and a .043" quench on 91 Octane, 93 when I can get it. No issues. Cam is a little bigger at 253*@0.050" and 110LSA. I run 36*total timing in by 3000rpms. I use vac advance to add 8* more under cruise.
Read your plugs and add timing a little at a time.
Choctaw Bob 02-13-2013 12:53 PM
I found in the building process that there is a great variation in the compression ratio calculators available because of the assumptions they have to make and liability issues. I found that when I calculated manually all the dimensions of my engine, my actual compression ratio was nearly a point lower than the calculator.
Also, you can reduce the dynamic compression ratio by retarding the cam. I can't say I remember how much but it does help.
In 1962, Chevrolet sold 425 HP 409s with 12.5 to 1 compression. The cars were shipped from the factory with 2 head gaskets each side to lower the compression a point or so. I remember that cause I had one.:D
barry425 02-13-2013 04:34 PM
I have a V-8 Chevy Vega with the early LT-1, 11.6:1 flat top forged pistons and a .010 quench (pistons stick out of the deck by .030, Felpro permatorque gasket .040 compressed). I run 91 octane (California) with timing set at 26 degrees (locked) and approximately 14 degrees vacuum advance. I shift at 8,000 rpm's with a Sig Erson Hi-Flow I hydraulic cam, ported and polished heads (2.02/1.60 iron heads right now), and it runs just fine. The tight quench makes the burn happen faster because of turbulence in the combustion chamber, so the mechanical timing cannot exceed 28 degrees. If you have any doubts about how this can work, check with Doug Roe (chief head design and intake manifold research engineer with Chevrolet for 17 years, now retired). This engine makes over 500 horsepower and gets 11 mpg with a 700R4, 3,000 rpm stall, and narrowed 12 bolt rear (3.08:1) with posi and Camaro suspension and brakes, 14 inch tires/rims (26 inch diameter). Line bore your engine first, then shot peen and resize rods, then buy, polish, and balance pistons (I used TRW forged flat tops), and then and only then deck the block for the quench. Pistons should stick out of the block between .020 and .030 with a .040 (compressed) head gasket. Any tighter and the rod stretch will let the pistons touch the heads. Any looser (less quench) and you lose torque. All quench benefits are lost if the piston to head clearance is greater than .030 inch. Gas mileage goes up, torque and horsepower almost double with the .010 inch piston to head clearance. Just don't make a mistake in machining. I use an HEI distributor with Pro-Comp's multiple spark discharge box. It does the same thing as a Digital MSD, but is way more reliable and 1/3 the cost.
vinniekq2 02-13-2013 04:45 PM
8,k RPM & .010quench
Ive used the Sig Erson high flow II cam and it was done a 6500 rpm.
Do you have a video of your car.I would really like to learn these secrets
