11/16-11 Bolt - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-19-2007, 10:36 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Originally Posted by OneMoreTime
Can you substitute a new bolt of a larger size and drill and tap new threads in the part you are trying to match up to, to accept that size?
Later, mikey
That is what I would do after spending some time and effort to find the original size..going to a 5/8 fine thread should not be all that difficult..
Sam[/QUOTE]
Now you got me confused.......a size larger would be 3/4 wouldn't it? 5/8 would be a size smaller.
  #17 (permalink)
Old 11-19-2007, 10:38 AM
Irelands child's Avatar
Originally Posted by powerrodsmike
( or a scottish engineer, those guys are stubborn )
Mikey,
Should I take that personally on my Scottish side??
Dave
Irelands child
  #18 (permalink)
Old 11-19-2007, 10:42 AM
Lost in the 60's
Wiki Edits: 4
( or a scottish engineer, those guys are stubborn )......................Thats better than being cheap...ha ha ha
  #19 (permalink)
Old 11-19-2007, 11:29 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sam
Now you got me confused.......a size larger would be 3/4 wouldn't it? 5/8 would be a size smaller. [/QUOTE]
that is what I do confuse people..Me included..
Sam
  #20 (permalink)
Old 11-19-2007, 11:32 AM
powerrodsmike's Avatar
Wiki Edits: 161
Originally Posted by Irelands child
Mikey,
Dave
You may, if you'd like.
Stubborness is a virtue, a sign of tenacity , the sign of a steadfast man of conviction and confidence.
I'd say that it was meant as a compliment.
Doesn't always mean you make the best decisions though.
"Cheap" is a compliment too, if you say "thrifty".
Kisses, mikey
BE different....ACT normal.
  #21 (permalink)
Old 11-19-2007, 11:42 AM
Kisses, mikey
Or:
1 a (1): unreasonably or perversely unyielding : mulish (2): justifiably unyielding : resolute b: suggestive or typical of a strong stubborn nature
2: performed or carried on in an unyielding, obstinate, or persistent manner
3: difficult to handle, manage, or treat
I think I prefer your definitions over the Merriam-Webster version.
As far as decisions, I can think of a couple in my past that were real bad and one of them was really really bad
Dave
Irelands child
  #22 (permalink)
Old 11-19-2007, 12:49 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I called Southern Bolt (its a local call for me} & the feller I talked too has me confused with another person looking for the same thing so I have to call back @ 3:30 to see if its still "order able".
It would be good to know the length needed.
Rick your not posing as Steve are you?
R
"SlowRide66"
"Illegitimis non carborundum"
  #23 (permalink)
Old 11-19-2007, 02:44 PM
Rob Keller's Avatar
Wiki Edits: 38
not available .
Sorry.
"SlowRide66"
  #24 (permalink)
Old 11-19-2007, 06:55 PM
Last journal entry: frame build
Did you try Caterpillar?
  #25 (permalink)
Old 12-20-2007, 11:45 PM
Last journal entry: Buick
Thanks for the responses. I had forgot about this post. It's been a while. I was not able to find the bolt. Although I was wondering if it would be possible to buy a 3/4-11 bolt and use the die (rethreader) to cut it down.
What do you think.
  #26 (permalink)
Old 12-21-2007, 12:05 AM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
that could work. i had a friend that had a simular problem. got a set of brake plates for his 66 impala to bolt on discs. minus hardware because it was free. i think he finally got the bolt through classic industries top bolt to the spindle. $14 each. on the flip side, when i was in high school, our drill team was using Springfield M-1903A3 rifles. we occasionally lost the bolts that held them together. our Sergent Major had them custom cut at a machine shop to repair the rifles. i think there was a minimum order, and it's been almost 20 years, but i'm sure it will be cheaper than $14 each.
  #27 (permalink)
Old 12-21-2007, 01:35 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I don't think that will work either. A standard 3/4 bolt has 10 threads per inch.
  #28 (permalink)
Old 12-21-2007, 05:48 AM
Wiki Edits: 161
You'll never get the die started on the larger diameter bolt, even if you could, a rethreader die has no cutting edges for the larger portion of the diameter.
You'd likely just spin the bolt in your vise, or break the die.
HTH, Mikey
  #29 (permalink)
Old 12-21-2007, 05:58 AM
My Solution
Hi Guys,
Thanks for all your suggestions! What I finally did is put a bushing in the chassis bracket (5/8-7/8), drill a 5/8" bolt & put a Zircon in it for grease, and use 2 nuts to lock the inside shackle on. I also had to drill the outside shackle so it fit on the non threaded end of the bolt.
Guess there's more than one way to skin a cat!
Steve
  #30 (permalink)
Old 10-17-2010, 09:47 AM
about 11/16-11 UNS bolts
I'm also looking for an 11/16-11 UNS bolt and learned that the designation "UNS" refers to "Unified National Special" threads which predominantly occur only as female threads like in tapped holes or in nuts. (more at http://en.wikipedia.org/wiki/Unified_Thread_Standard)
I'm hoping to find threaded rod or perhaps eye bolts with 11/16-11 UNS thread from this manufacturer of the Manta Ray earth anchor models MR-3 and MR-4: http://foresightproducts.com/
My custom application does not allow for sizing up or down so I'm stuck with 11/16-11 UNS.
Anyone learn if Cummins has 'em?
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-28-2004 11:41 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
12 bolt rear end Fireguy0712 Transmission - Rearend 1 07-26-2003 05:39 PM
