11/16-11 Bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2006, 12:30 PM
Last journal entry: Buick
11/16-11 Bolt
Guy's I need an 11/16-11 bolt for the suspension of my Cady. I've looked everywhere and can't find this odd size. It seems they only make 5/8 or 3/4 bolts. Any idea where I might be able to get one
Thanks Rick
Old 05-30-2006, 12:39 PM
astroracer's Avatar
What year Caddy? Dealership? Could it be metric? Could you go bigger or smaller?
Mark
Old 05-30-2006, 04:22 PM
It's a 37 Cady. Metric will not work. No dealer parts. Check out my journal for a more detailed view.
Old 05-30-2006, 11:44 PM
techinspector1's Avatar
Wiki Edits: 326
Anyone with a lathe can turn you out a bolt pretty quick using hex material.
Old 05-31-2006, 09:00 AM
machinist & fabricator
stop looking at hardwear and auto stores... and go throuh industrial suppliers.
key up on the net for places like these:
MSC
Harbor freight
Grainger
most of these places have what ever you need.... the only thing is they have millions of part numbers, so you gotta find the right one, mabe a online catalogue.
prolly cost ya 20 dollars after shipping.. but better than going to a machine shop and paying shop rate.
Old 05-31-2006, 09:45 AM
ckucia's Avatar
Also check out McMaster-Carr (www.mcmaster.com).
Industrial supply - extensive online catalog - and they sell to the public.
Pricey though.
Old 05-31-2006, 10:09 AM
T buckets rule
I am not positive but I think a big cummins diesel uses 11/16 head bolts. If you have a big truck repair shop or dealer close by you might check with them. You might find something that will work.
Old 05-31-2006, 11:13 AM
You've tried "bolt" supply stores in your neighborhood, e.g. Abilene Bolt? They probably have a minimum sale but most industrial suppliers will sell to walk-ins too. Often the best source is to ask your hardware store where they get their bolts from.
Old 06-01-2006, 01:39 PM
Thanks for the replies. I never thought about a head bolt. I used to work in a diesel shop and from what I remember they may very well be 11/16.
As far as bolt suppliers, Abilene has quite an extensive supply of them servicing the oil drilling industry; I've checked them all and none have any.
Keep the ideas coming and I'll keep looking.
Rick
Old 11-18-2007, 08:10 PM
Did you find a bolt?
Hi,
I'm looking for a similar bolt for my 1937 Buick rear suspension. It's about 3.5" long & threaded all the way.
Did you find one?
Thanks,
Steve
Old 11-18-2007, 08:39 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I have a local Nut & bolt place here .
usually if they can't get it you don't need it
I will give them a call if you would like ..or you can call them your self
352-732-3904
Southern Blade & Bolt
Don't bother looking on the Web for them
Its a old time mom & pop thing
R
"SlowRide66"
"Illegitimis non carborundum"
Old 11-19-2007, 08:22 AM
Still No Luck
Hi,
Thanks for the lead but Southern doesn't have it either!
Steve
Old 11-19-2007, 08:44 AM
Irelands child's Avatar
It's an obsolete size - the older Ford tie rod ends have an 11/16" lock nut - and that's about the last usage that I know. Fastenal doesn't have them and that would be my last gasp place to look - and I even used to have a tap.
Irelands child
Old 11-19-2007, 09:01 AM
powerrodsmike's Avatar
Wiki Edits: 161
Like Dave said, that is one of those oddball thread sizes, most likely specified by some engineer who didn't know that theads were soon to become standardized. ( or a scottish engineer, those guys are stubborn )
I looked and looked for a NUT of that size a while back, it was for the Seagrave fire truck. I found nothing, and the guy didn't take me up on my offer to make him a few.
I did find a die of that size and pitch,
http://www.shoprutlandtool.com/webap...roductId=10144
But it is only a re threader.
It is an easy task for any machine shop (or anyone with a lathe with thread cutting capabilities and a 60* lathe bit),to make a new bolt with that thread .
You wouldn't even have to make it out of hex bar stock, it could cut thread on the entire length and put nuts on the end...(ends?)
Can you substitute a new bolt of a larger size and drill and tap new threads in the part you are trying to match up to, to accept that size?
Later, mikey
BE different....ACT normal.
Old 11-19-2007, 10:23 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Later, mikey[/QUOTE]
That is what I would do after spending some time and effort to find the original size..going to a 5/8 fine thread should not be all that difficult..
Sam
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-28-2004 11:41 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
12 bolt rear end Fireguy0712 Transmission - Rearend 1 07-26-2003 05:39 PM
