Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 11" rear drums lock first.
Old 09-06-2011, 08:10 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally Posted by ss396si
What kind of adjustable distribution block do I need? The kind that replaces my excisting prop block or the one that goes behind it?
This kind. Left click on the image for a larger view. Available at most aftermarket suppliers. I like Speedway for my source. Use the Wilwood or the Speedway brand.
This unit installs after the master cylinder in the rear line. It can reduce the rear line pressure up to 60%. Turning the adjustable valve all the way clockwise is wide open. (Reverse from what you would think).
Name:	adjustable proportioning valve.jpg
