Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 11" rear drums lock first.
Old 09-06-2011, 04:15 PM
ss396si's Avatar
ss396si ss396si is offline
Originally Posted by OneMoreTime
The factory prop valve is calibrated for the original brake setup and works fine on a factory car. when we change the brake setup as you have done then the old calibration does not work and then you need the adjustable prop valve..
Sam
How close does the adjustable prop valve need to be to the distribution block? I would need to buy extra steel lines for this install as well?
