Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 11 spline 1.5" shaft
Old 04-17-2006, 01:32 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
Can you seperate the U-joint portion and adapt to a newer joint from there back?
If not what is the spline count of the output shaft of the transmission, and can you have something fabricated from that point.
It looks as if you are going to have to have some part fabricated, but like you stated, you already have the transmission.
