11 spline 1.5" shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 01:32 PM
machinist & fabricator
hay guys, im trying to mate a 32 pontiac 3 speed manual trans to a mid 70's GM 10 bolt.
on the back of the trans has a bolt on adapter plate.
one side is splined into the tail shaft to the transmission, and retained by a bolt and a cotter pin. (that extrudes past the surface of the flange)
the other side is a casting, which has an old style U joint within it. and the other side of the U joint has a 11 spline 1.5" female yoke.
my questions are,
was a 32 pontiac (im sure same as chevy) a open or closed driveshaft/torque tube?
ive been told many a times that ill probally have to make it, if so where can i get a splined shaft that will fit that yoke?
is there a better way to go about this? mabe a flange that someone makes that will accept a modern style u-joint?
and if ya tell me to use a better trans, ill tell you to provide the parts,
thanks!!
Old 04-17-2006, 02:32 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Can you seperate the U-joint portion and adapt to a newer joint from there back?
If not what is the spline count of the output shaft of the transmission, and can you have something fabricated from that point.
It looks as if you are going to have to have some part fabricated, but like you stated, you already have the transmission.
Old 04-17-2006, 03:18 PM
i thought about replacing that u-joint with a plate, drilled out to the bolt pattern, and then welding the driveshaft ears on it. but if i do that, then there is 0 ammount of slippage between the rearend and tranny.. and in my experience, thats askin for trouble!
i think mabe the best way is to take this adapter off and use it like a regular trans, but i havnt taken that adapter off, i will tonight to see whats goin on.
my plan is of now to use the old adapter, and trying to find a splind shaft and
welding it to a normal driveshaft tube . so the front is a fixed shaft and the rear has the ears for the U-joint.
dont really like that plan, but whatever gets me around Paso Robles 06!!!
Old 04-17-2006, 07:54 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
You could always use a truck style driveshaft with the self contained slip yoke on the shaft.
As long as you have a place to bolt a universal joint to the output of the transmission.
Here's what you thought you needed (on top), with what you might be able to use on bottom:
Old 04-18-2006, 12:01 AM
i took the adapter off the engine tonight, and i might beable to turn the bolt flange off and weld a set of driveshaft ears on it. if i can... i got that modification in the bag!!!
thanks for your hewlp man
brian
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
Go Cart? mustangdude947 Engine 23 12-20-2005 11:02 AM
727 output shaft spline fat50 Transmission - Rearend 4 10-05-2004 07:49 AM
12.5 hp go kart airbag_89 Introduce Yourself 2 08-24-2004 11:22 PM
Shaft rocker trouble uhhh not good Venturat Engine 1 08-04-2003 10:24 PM
