110 volt Mig welder ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2009, 05:29 AM
Anybody using one?
I just took a lesson using a Miller 125 rosen core wire feed 110 volt welder, piece O cake.
Looking at a Hobart 125 EZ and the Hobart Handler 140 and comparable Miller's and Lincoln's.
Old 10-27-2009, 07:26 AM
Ratdoggy's Avatar
Hammer torch chisel...
Last journal entry: Wheels and tires
I have the Hobart 140 I believe.. Great for thin stuff and it's like caulking, very easy to learn to MIG weld.
Old 10-27-2009, 07:56 AM
We have five Miller 135 MIGs in the shop that do everything but actual frame welding. Well, even that but no frame sectioning. Other than that, every single unibody "frame" and everything else that is welded in the shop is with them.
Old 10-27-2009, 09:22 AM
Wiki Edits: 49
I have a Lincoln weld-pack 100 flux core that I use for thin stuff and where I intend to grind my welds. I also have a Lincoln Power Mig 140 that I use on thicker stuff and especially where I know the weld will show. Flux core welding spatters a lot and even the best weld looks crappy without grinding. When using gas it is MUCH easier to get a nice professional looking weld.
Old 10-27-2009, 11:46 AM
mig
Thanks guys.
I meant to say flux not resin.
New Hobart MIG welder Chris Kemp Garage - Tools 1 04-08-2009 12:36 AM
Mastercraft Mig welder? Canadians eh montea Garage - Tools 19 01-23-2007 11:24 AM
Using A mig Vs Stud Welder. satexasf150 Body - Exterior 1 07-24-2006 10:08 AM
Seeking MIG welder recommendations Slipangle Garage - Tools 6 10-20-2004 09:04 PM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 07:31 AM
