110 volts or 220 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2007, 01:01 PM
110 volts or 220
Anyone know if a 220 volt air conditioner uses less electricity than a 110 volt of the same size,thanks for your reply on this off topic.
Old 05-13-2007, 01:22 PM
If both air conditioners are both the same except one is 110 and other is 220 yes the 220 machine will draw less current in amps....
Old 05-13-2007, 02:51 PM
To get the same output you need to put in the same input, theirs no free ride its the same amount of electricity to do the same work. Watts = Volts X Amps. So 220V uses half the amps but twice the Volts. 110 uses half the Volts but twice the amps.
Jordon
CB radio on 6 volt system Nightfire Electrical 19 04-25-2009 09:49 AM
starter solenoid shorting ignition junkyardjeff Electrical 5 03-24-2007 05:15 PM
i have 2 volts with the key off Waksabi Electrical 10 06-30-2006 07:11 PM
220 wiring for welder cboy Garage - Tools 25 02-22-2005 03:07 PM
110 ARC vs 110 MIG Cowtown Punk Suspension - Brakes - Steering 6 08-28-2003 04:49 PM
