Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 110V Arc welder for panels???
Old 08-31-2012, 11:47 PM
monster76 monster76 is offline
yes you can but its not ideal, i have welded a few thin still panels with an arc welder. remember if you do decide to try it out, thinner rod require less amperage so use he thinnest rod you have available and forget about chipping the slag its better to use a grinder or drill with wire wheel to remove slag so you dont put any dings or dents in the metal, also arc length is critical so you dont blow any holes in your sheet metal
