110V Arc welder for panels??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-01-2012, 04:54 PM
I have owned a 110v arc welder before but also used acetylene, and mig. You can be sure that the ARC welder was w a y down on the bottom of the list for use on sheet metal. Can it be done? yes, if you are good enough. Does it make sense for a beginner to learn with an ARC welder? Absolutely not, in my opinion. I sold my 110v arc for 65 dollars because I was tired of walking around it. If all you can afford is a flux core from H/F do what you have to do but by the time you get good enough to use an ARC welder you will have ruined more than you have fixed.......One man's humble opinion.
  #17 (permalink)
Old 09-01-2012, 05:47 PM
rusthater89's Avatar
You can certainly use an arc welder to weld sheet metal. I use it all the time on 16-22 gauge steel.
Use 1/16 6013 rods at 40 amps. I take a rod and using a wire cutter i crack and scrap all the flux off of it. I take another rod and attach it to the electrode clamp.
When you start the arc with your free hand feed the "bare" electrode into the pool. It will keep it from burning through.
You will need practice though. Especially with starting the arc with one hand as you need the other hand to feed the "bare" rod into the pool.
I also like using the "bare" rod as a sort of poker. For example I use it to help manipulate the weld pool to cover large holes and gouges.
I rarely use copper plates.
Of course what I mentioned will take a bunch of practice so don't just start welding up your car right away or else you will be in a world of fustration.
Keep a wire wheel on a grinder handy to knock off the flux. Also if you weld over the flux, if you can keep the rod over the flux for a few secounds it will cause it to rise to the top without causing inclusions thus saving the need to wire wheel off the flux. Of course on thin 22 gauge steel this technique is not practical but I figured it is good advice to give.
trouble striking an arc with a stick welder tutorfetch General Rodding Tech 3 12-18-2010 09:05 PM
Lincoln AC 225 Arc Welder yzair Garage - Tools 5 06-26-2010 10:30 AM
Best 110V welder Dale Sizemore Garage - Tools 22 01-18-2006 11:10 AM
220V welder or 110V Ripped Body - Exterior 8 10-04-2005 07:34 PM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 07:31 AM
