12 bolt to 14 bolt 77 c10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 08:56 PM
Hello,
My truck is a 1977 c10 with a 12 bolt truck axle. I'm worried it wont hold up and have found a 10.5" 14 bolt ff. What do I do about brakes? I was going to convert the 12 bolt to cross drilled disks (13" outta LMC). Was gonna run 20" rims to clear em.
Forgot to add that I'm thinking about a TKO-600 or T-56 mag tranny. It will have a supercharged 454 so worried about breaking stuff...
Greg
Old 02-14-2011, 04:38 AM
If you're that worried about breaking the rear,go to a 9" Ford rear. Some were a bolt in for those trucks & even had factory disc brakes. I would not put a 8 lug rear in it.
Shane
Old 02-14-2011, 10:45 AM
75chev4x4's Avatar
Off road design makes a disc kit for the 14 bolt ff if you want to look on there site.
Old 02-15-2011, 08:28 PM
thanks for the website.
Why not an 8 lug? Lack of rim selection?
Not really a fan of the 9" but I do plan on looking in the "junkyard" (sad junkyard) for one while I'm there.
Brakes... If I found a factory disk than I could just plug my lines into it? Of course I see I need to switch my proportion valve for one for disks all around.
No one mentioned it but not worried about suspension lining up because going to 4-link with coil overs.
Greg
Oh yeah, kinda worried about breaking it. I hear the pinion stem is small on the 12 bolt truck axle. Thing is the ring broke on it
Old 02-16-2011, 06:41 AM
Rim selection,the odd hubs,additional unsprung weight.
Shane
Better core block for sbc 383, 4-bolt flat or 2-bolt roller? Cousin_Joe Engine 24 02-08-2008 08:50 AM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
