12 bolt axle play - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2012, 11:55 AM
boobert's Avatar
12 bolt axle play
Hey all, I have a 67 Nova with a big block 402. It has a pretty fresh (about 2000 miles) 12 bolt Posi rear end. 3.73 Richmond gears with an Eaton posi. Toms axles. I noticed awile back while backing up and turning I was getting thumping noise from the drivers side. You could actually feel it. Anyways today I got around to checking it out and it seems to me that the drivers side axle has a little too much play causing this problem. I don't beat up on this car too much and everythings fresh built by a well known diff builder. Any ideas? Thanks in advance.
Bob.
Old 09-21-2012, 03:32 PM
big gear head's Avatar
High Performance Rear Ends
The noise is coming from the cutches in the Eaton. Did you use the GM oil additive when you filled it up?
Old 09-21-2012, 03:47 PM
Sometimes the 12 bolt takes 2 bottles.
Old 09-21-2012, 04:20 PM
boobert's Avatar
Ya I used the additive
Old 09-21-2012, 04:56 PM
Was it the GM additive or was it something else?
Old 09-21-2012, 05:13 PM
boobert's Avatar
It was GM, but why only in reverse and while i'm cranking the wheel.
Old 09-21-2012, 05:38 PM
boobert's Avatar
The gear shop out in Paramount,ca. built this diff I had it shortened and some perches added. When I picked it up they gave me Lucas gear oil and 2 bottles of GM LS additive
Old 09-21-2012, 09:25 PM
This is a comon problem with clutch type limited slip differentials. Most of the time you only hear the noise and feel the car jerk at low speed and when making a sharp turn. Most of the time the GM or Ford additive will take care of the problem.
A new Eaton Posi should have the clutches tight enough that there will be very little axle end play. If you have a lot of axle end play then you might have some damaged clutches. A Eaton Posi that is set up correctly should have about .005 to .010 axle end play, but factory set up clutches might have more.
Old 09-22-2012, 11:00 AM
Another variable is the thickness of the c-clip button when using aftermarket axles
Old 09-22-2012, 03:13 PM
The c clip button on a 12 bolt axle is suppose to be .312 inch thick. Good axles are right on this number, but some of the cheap axles like Alloy USA will vary.
Old 09-22-2012, 09:03 PM
vinniekq2's Avatar
are you still using C clips?I would think a shortened diff would have good axles?
Old 09-22-2012, 09:40 PM
boobert's Avatar
Still using c clips, the axles are Toms and very good.
Old 09-22-2012, 11:22 PM
vinniekq2's Avatar
Take it back to the guy that built the diff. I really dont understand why you still use C clips? The pressed bearing axle is less like to lose a wheel "when " the axle breaks. 12 bolts do break if you race or have good traction and a healthy engine. On my car,the tires are the fuse,,,
Ford 8 inch axle end play junkyardjeff Transmission - Rearend 12 04-24-2010 05:49 AM
Axle end play 428ho Transmission - Rearend 5 09-17-2008 09:52 AM
S-10 Axle play Problem? AMDAP Transmission - Rearend 46 03-11-2006 12:58 PM
Axle Play Problem 71gtx Transmission - Rearend 9 08-20-2004 12:21 PM
Rear axle bearing play Seon Transmission - Rearend 2 12-11-2002 03:54 PM
