12 bolt axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2006, 01:32 PM
Derkyb's Avatar
12 bolt axles
Anyone know how many axle splines are on a 12 bolt in a 70 chevelle 28 or 30? How much abuse will the stock axles take? Have a 496ci not looking to race alot but thinking I should buy aftermarket axles, opinions please.
Old 08-13-2006, 02:16 PM
Will I ever get it done?
Last journal entry: Hood
IMHO I would go with a c-clip eliminator kit and a good set of street axles from Moser or one of the other axle companies. You've probably spent a chunk of change already on the 496. Good axles and no c-clips are cheap insurance over replacing a quarter panel or worse.
Old 08-13-2006, 09:10 PM
A Moser rep told me C-clip eliminators tend to be leaky, and he recommended using their replacement C-clip-type axles for street use. He said the only way to lose the C-clips without the leak potential was to completely change the ends of the axle tubes ($$$$$).
30 splines for a normal 12-bolt.
Old 08-13-2006, 10:21 PM
Hadn't heard about the leakage, but it makes sense. I still think I would get the ends swapped out and use pressed on bearings for a 496. I would just rather be safe than sorry. Using the Moser c-clip axles would be my second choice. I wouldn't go with anything less.
Old 08-14-2006, 12:53 AM
If you put disc brakes on it you don't need to worry about loosing a wheel if the axle brakes. Not NHRA approved but drum brakes suck anyways...just a thought.
Old 08-14-2006, 07:53 AM
Derkyb's Avatar
Hadnt thought about the disk brakes may do that in the future. I think im going with the aftermarket clip axles for now and do a serious upgrade when Im ready to run slicks. Thanks guys.
Old 08-14-2006, 09:28 AM
The stock 12-bolt axles on a 70 Chevelle are quite small, about 1.085" at the smallest place. They are smaller than the stock Ford 28 spline axles in my Granada rear, which measure 1.17".
12 bolt axle info. tiburon62 Transmission - Rearend 5 11-24-2005 08:23 PM
Would it be possible to shorten 12 bolt? shockers69 Transmission - Rearend 4 01-05-2004 01:03 AM
12 bolt rear end question Roy_67_SS350 Transmission - Rearend 3 01-04-2004 06:12 AM
just swapped to a 12 bolt and the yolk is wrong! Destructo Transmission - Rearend 6 10-14-2003 08:54 PM
12 Bolt car and truck rear ends the same? zachscc Transmission - Rearend 2 01-18-2003 07:29 AM
