12 bolt chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2010, 07:32 PM
12 bolt chevy
ok guys i think i really screwed up need some help bad i hade to replace my yock on my 12 bolt and its a brandnew rearend so i put the new yock in and now my rearend is kindda tight to turn did i screw up the pinion gear thank jerrod
Old 09-18-2010, 07:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You may have crushed the pinion sleeve too much when you tightened the nut. This will cause the pinion bearing preload and gear pattern to change- unless you have a solid spacer instead of a crush sleeve.
Old 09-18-2010, 07:52 PM
well do you think i should have the rearend checked from the guy who built it before i put it on the road i was also told that it might give me road noise and premature where the ring and pinion and bearring
Old 09-19-2010, 01:28 PM
big gear head's Avatar
High Performance Rear Ends
If you got it too tight then you will probably have a pinion bearing failure. I would take it back to the builder and have him check the preload on the pinion bearings.
Old 09-19-2010, 05:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would heed big gear head's advice- he works on rear ends for a living.
Good luck.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
10 bolt to 12 bolt conversion Jethrotrc Transmission - Rearend 1 08-15-2010 10:36 PM
10 bolt or 12 bolt???? tinman386 Transmission - Rearend 14 07-31-2007 02:03 AM
How to identify Oldsmobile 12 bolt? elukas Transmission - Rearend 8 12-13-2003 10:59 AM
Rear disc calipers -which ones? Chevy 12 bolt Chevl_Steve Suspension - Brakes - Steering 0 01-27-2003 02:15 PM
