12 Bolt chevy gears questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2009, 10:09 AM
Tbone714's Avatar
Hey fellas,
I've been looking for gears for the past couple weeks on ebay and craigslist, and I think i finally found a pretty good deal, but i could use some help picking the right one because I dont wanna be stuck with something i cant use. the item in question are some 3.73 Gears for a 12 bolt 69 Camaro Z28(41-11). I've got a 74 Chevy Shortbed with a 12 bolt rear as well, and it would seem that these gears would be perfect for my truck but the only thing i'm not sure about is the ring and pinion diameter. Hopefully someone can tell me if these parts are just flat out interchangeable, or if they cant be swapped at all. Thanx
Old 04-22-2009, 10:18 AM
302 Z28's Avatar
Don't pay extra for the description 69 Z/28 gears, all 12 bolts are the same, there are no specific gear sets for 69 Z/28 or for that matter Camaro period.
Vince
Old 04-22-2009, 10:38 AM
Tbone714's Avatar
So your saying that a GM 12 bolt 8.5 "C" Axle (That which is used in a camaro) is the same thing as a GM 12 Bolt 8.875 (Truck Axle), Even tho the Diameter of the Pinion in the Truck axle is 1.438" and the diameter of the Pinion used in the camaro is 1.625"? You would think the Difference in Diameters would change things up a bit?
Old 04-22-2009, 10:57 AM
prostreet6t9's Avatar
Differential/Driveline
The parts will not interchange! 12 bolt car and 12 bolt truck use different gear sets.
Old 04-22-2009, 11:02 AM
Here is some gear sets>>>>> http://www.ringpinion.com/PartsList....b-Differential
Old 04-22-2009, 11:10 AM
Both car and truck 12 bolts are a 8.875 ring gear. What ratio do you have now? and what ratio do you want to go to?
Old 04-22-2009, 11:14 AM
Tbone714's Avatar
3.08 to 3.73
Old 04-22-2009, 11:43 AM
3.08 to 3.73
You will need a THICK ring gear set for what your doing like this >> http://www.ringpinion.com/ProductDet...spx?ProdID=544
You can do some shopping on the net for the best prices,Just make sure your looking at a gear set for the 12 bolt "truck", it's a "thick" ring gear and the gear set fits 342 and higher ratio's.
Old 04-22-2009, 11:44 AM
I was under the impression that CAR 12 bolts and TRUCK 12 bolts were completely different animals.
Are you experts saying the ring and pinion from one will interchange into the other?
JA
Old 04-22-2009, 11:52 AM
JA
Read post#4!
Old 04-22-2009, 11:55 AM
Tbone714's Avatar
Thanx for the Conformation Prostreet. Always nice to talk to someone that knows what their talking about.
Old 04-22-2009, 11:57 AM
You're Welcome!
Old 04-22-2009, 07:47 PM
302 Z28's Avatar
Sorry, I di not mean to imply that all 12 bolts were the same, only that a gear set that went into a 69 Z/28 12 bolt was no different than any other gear set for Camaro, or Nova. A lot of people pass off stuff as for a 69 Z/28 when it's not.
Vince
Old 04-22-2009, 08:19 PM
Vince
I knew where you were going with that
12 bolt (truck rear end) questions Dylanic_350 Transmission - Rearend 4 02-11-2009 06:52 PM
Need help selecting ring gear - Chevy 12 bolt heyjude076 Transmission - Rearend 14 09-09-2008 05:16 PM
12 bolt carrier in a 10 bolt housing wagonman65 Transmission - Rearend 8 01-02-2008 02:54 PM
12 Bolt shortening, narrowing kmkommes Transmission - Rearend 9 11-28-2004 08:09 PM
How to identify Oldsmobile 12 bolt? elukas Transmission - Rearend 8 12-13-2003 10:59 AM
