12 bolt differential from a 1970 chevelle fit a 1967 chevelle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 05:50 AM
Will a 12 bolt from a 1970 chevelle bolt up to my 1967 chevelle?
Old 04-04-2013, 06:25 AM
Banned
YES.. but the 70 is wider iirc it's an inch on each end..
Old 04-04-2013, 07:32 AM
kso's Avatar
kso kso is offline
Yep, it's a bolt-in but wider. And, that matters on the '67's smallish fenderwells.
See if the axle bearing surface is shot...if you have to get new axles anyway, you might get narrower ones and have the housing shortened, 'cause '64-67 12-bolts are like hen's teeth these days.
Old 04-04-2013, 08:29 AM
big gear head's Avatar
High Performance Rear Ends
The '68 to '72 Chevelle 12 bolt is exactly 1/2 inch wider per side than the '65 to '67 Chevelle 12 bolt. That's 1 inch wider over all. It is a bolt in, but if you have tire clearance problems then it might require some new wheels with 1/2 inch more back space.
Old 04-04-2013, 02:47 PM
Banned
yup, mine was 1" per side as I added disc brakes..
Old 04-04-2013, 05:22 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
I just added disc brakes to my 66 Chevelle SS 12 bolt ,I used calipers ,Rotors and backing plate from a 10 bolt firebird what did you do about your shock mount .?? on the front I used a 70 Monte Carlo disc brakes and spindles since 66 did not come with disc.and I didn't want the troublesome calipers from a 67,
Old 04-05-2013, 06:53 AM
Banned
moved it in 1"
Will a 69 Chevelle rearend fit my '67 Chevelle lt1_performance Transmission - Rearend 2 04-26-2008 10:10 PM
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
1967 Chevelle Ss pattide Introduce Yourself 3 04-30-2006 02:58 PM
1970 chevelle ss 12 bolt tombo615 Transmission - Rearend 8 01-17-2006 01:09 PM
