Those 10.5 tires are going to evaporate too!!
Go for a Ford 9". Back in the 70's I raced a big cube BB Nova. I spent a small fortune trying to make a 12 bolt live. Welded/braced tubes, billet caps. Summers Bros. axles, Moroso unbreakable center. Still broke TONS of parts. In those days a Chevy man wouldn't dare put a Ford rear in a GM car. But, now it is acceptable. Economical and reliable. Fairly lightweight. Sure would have saved me a lot of CA$H. I eventually went with a Dana 60 rear. Huge, heavy and not without its own problems. |
yes I know, but I have to race on them .... class rules. ... about that 9 inch. do I need one of those aftermarket units or can find an old piece, and install a new set of aftermarket axles and a quality center section? sune |
If your racing it competivly, I suggest calling Currie Enterprises.
If you playing around you might get away with a 9" but the money you will have invested will be a liitle short of the unit you won't break from Currie. If you have the money and no rules, Currie If bound by money and rules, an aftermarket 9" |
You can have a 9" in your car and not have a single Ford part. The one I just built doesn't have a Ford part in it. It is all aftermarket and I used all Currie parts (except the axles are Dutchman).
How heavy the car is also makes a difference. If it is a 3500lb car then it will be harder on the rear end than a car weight 2500lbs. I agree with that kind of power the 12 bolts will have a short life. This assumes the car will hook and with that kind of power it better hook. |
Do the 9 inch , you won't be sorry.
Moser Engineering has about anything you need , from complete rears to custom axles. |
| 3rd Gen F-body rear discs on 65 A-body 12 bolt? | smallblocker2 | Suspension - Brakes - Steering | 7 | 03-22-2006 12:51 AM |
| Good price for 12 bolt? | 69ChevelleAddict | Transmission - Rearend | 7 | 06-30-2005 10:10 AM |
| New 12 bolt rear? | strikingthematch | Transmission - Rearend | 3 | 07-28-2004 11:41 PM |
| just swapped to a 12 bolt and the yolk is wrong! | Destructo | Transmission - Rearend | 6 | 10-14-2003 08:54 PM |
| 10 bolt or 12 bolt rearends ? | a62chevy | Transmission - Rearend | 5 | 09-21-2003 05:16 AM |
