12 bolt gear options? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2012, 03:22 AM
Hey everyone
I'm looking to change the gears in my GM 12 bolt passenger car rear end.
Its currently a 3.07 and I would like to go to a 3.90. However it looks like the highest I can go with the stock carrier is 3.73, is this correct? or do the aftermarket ring/pinion sets work with higher gear ratios?
Thanks
Jordon
Old 08-22-2012, 04:39 AM
Idk for the 12 bolt but for dana axle they sell thick gear sets to use the 3.73 down carrier. Im assuming they should to for the 12 bolt
Old 08-22-2012, 05:55 AM
big gear head's Avatar
High Performance Rear Ends
The 3.07 fits a 3 series differential in the Chevy 12 bolt car rear end. You can go as far as a 4.88 on the 3 series with the thick after market gears. There are special thick 3.91, 4.11, 4.56 and 4.88 gears that fit the 3 series.
Richmond Gear 5-speed,Why all the first gear ratio options? Argess Transmission - Rearend 1 10-17-2011 07:11 AM
2.73 posi (10 bolt 8.5?) gear upgrade options DQ81 Transmission - Rearend 3 03-23-2011 04:39 PM
bodymount bolt options/suggestions wanted matts37chev Body - Exterior 2 01-21-2011 06:43 AM
12 bolt 4.56 gear ? jody chevelle Transmission - Rearend 8 02-04-2006 12:19 PM
rear gear ratio options. s-10 Evan Transmission - Rearend 2 08-16-2003 10:49 PM
