12 bolt gear ratio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2005, 08:26 PM
msc66's Avatar
Last journal entry: pics
12 bolt gear ratio?
Can anyone tell me if a 12 bolt chevy (passenger car) ever came with a 3.36 ratio gear.
Thanks in advance!
Old 01-09-2005, 06:20 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I haven't heard of that exact ratio yet, but they did come with 3.31, and 3.42 is an option.
Old 01-09-2005, 09:17 AM
msc66's Avatar
Thanks, that's what I thought. There is a guy selling a ring and pinion on ebay that he claims is 3.36. He says the tooth count is 11 and 37?
On a separate note, how can you tell a truck ring and pinion from a car by looking at it.
Thanks
Old 01-09-2005, 04:01 PM
Last journal entry: PICTURE TEST
gears
I seam to remember seeing a 3:36 ratio offered in some of my old chevelle books but i will need to look to be sure... I know that the 3:31 was a standard though. Is it a gm r/p or a aftermarket???? It might be a aftermarket r/p...
The truck pinions are 1.437" dia and the car pinions are 1.625" dia where the bearing closest to the teeth are. i am not really sure that you could see it in a picture though. I guess it would depend on the way the picture was taken...
Keith
Old 01-09-2005, 05:01 PM
gears
ok in one of my old chevelle reports i found this.
In 1970 they offered a 3:36 gear in both the standard (10 bolt) code CCG and in the heavy duty (12 bolt) code CGC open and CGI posi......
So i would say that gm made 3:36 gears for the 12 bolt...
They also offeded the 3:31 and 3:36 in other years but in the listings they are not clear about if it was 10 bolt or 12 bolt availibility.
Keith
