12 Bolt how much power can it handle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2006, 04:16 PM
1baddeuce's Avatar
I am considering building a street driven 67 Nova with a Shafiroff 540 or 598. My question is what will a 12 bolt need to handle up to say 700-800 hp. Can a posi handle that or will I need to run a spool etc. Currently I am running a 10 bolt with a spool, strange axles and just shy of 500 hp 408 small block with a powerglide. The spool has been fine other than dragging the tires around corners. I would prefer to keep my car all GM but am not against using a Dana or 9inch.
Thanks,
Rick
Old 09-09-2006, 05:56 PM
BOBCRMAN@aol.com's Avatar
It's not really how much H Power will it take but how much Traction. If the car spins the tires the twelve bolt will last.
In my experiance tho. If you have a car that hooks. That twelve bolt will take a LOT of hard earned cash to get it to take the same punishment a basically stock 9" will endure. Been There!
Old 09-10-2006, 08:44 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
I am running a 12 bolt in my Biscayne with 4.56 gears and a Moroso Brute Strength carrier. The engine I'm running dynoed at 608@7200, but since it is a 433, the torque isn't as high as you'll see in a larger inch engine. I haven't used the NOS Big Shot system yet, so we'll see how much it can handle. So far there have been no problems. It's backed by a turbo 400, but that is being changed out this winter to a manual trans. The tires are Hoosier Quick Time 295's. I hope this helps.
Old 09-12-2006, 12:36 PM
T buckets rule
I would go with a Dana 60, spool and some axles. Pretty much bullet proof.
You will have to buy all that stuff for a 12 bolt any way. Might as well start with a better rear end.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 01:51 AM
Good price for 12 bolt? 69ChevelleAddict Transmission - Rearend 7 06-30-2005 11:10 AM
12 Bolt shortening, narrowing kmkommes Transmission - Rearend 9 11-28-2004 09:09 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 06:16 AM
