Trying to get axle length info. I don't know what this rear end came out of. There were only 2 sizes, right? 28.25" or 29.5" My axle code is DH 10 30 G. Flange # is I 154. An new Eaton unit (series 3 carrier) is currently in there with in/out axle play of 1/8" which seems right.
Probably:
DH = 1965-1969 Posi 3.31:1 (15/16000 H.D. series)
(note that below the DH code is a D or E code (Dana or Eaton posi unit)
10 30 = October 30
G = Detroit Gear and Axle (plant)
Bolt dia=3/8
Ring Gear dia=8.875
Pinion dia=1.625
Axle splines=30
Axle tube flange to axle tube flange=58 1/4
Between centerlines of control arm brackets=43 1/8
Axke shaft length=31 15/32
Possibly:
DH = 1975 Monza 2.56:1
10 30 = October 30
(problem is after 1970 they used day of the year ex: Jan 30=030)
Check with Moser (online? or call), they will have more axles than Summit listed. Get a part number and a price. Then go back to summit, see if they can price the part number (might be less than direct from Moser).
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
