12 Bolt Olds Rearend With 12 Bolts On Ring Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2009, 06:17 PM
12 bolt Olds with 12 bolt ring
I also have one of thes erear ends, mine came from a 1970 Delta. I can't remember if it was an 88 or 98. They have 31 spline axles and mine is a series 2 carrier with 2.56 gears. I have a question in to Summit now to see if "C" Type gears will fit. I have also seen this rear end in a 72 Delta 88 and a 73 Buick Riv. I have not confirmed if these were the 12 bolt ring but the housing appears the same.
Old 09-20-2009, 10:39 PM
ericnova72's Avatar
More for Less Racer
These rears are not the same as the 12-bolt "C" Chevrolet car axle and parts don't interchange as far as I know, maybe some of the bearings and seals but not the gears. I don't think there are any performance parts for this rear, it is pretty much a dud.
