Hotrodders Bulletin Board
#1
12-Bolt Posi
I picked up a '66 12-bolt, 3.31, posi unit for my '67 and disassembled it as far as my limited rear end expertise allows, i.e. axles and the carrier are out. It's an Eaton unit and I have to assume it needs rebuild.
Having never tackled these before, does anyone have a step-by-step guide for the "knowledge-impaired technician". Also, what do I look for in terms of bad posi parts? Thanks. |
#2
re: 12-Bolt Posi
I've never had an Eaton unit apart... no help there. I moved your duplicate post to the dump.
======== Be kind to your children... some day they may be decide what nursing home to put you in |
#3
re: 12-Bolt Posi
Oops. My bad.
Back to top |
Similar Threads for: "12-Bolt Posi"
| 12 bolt posi id | CHEVELLE12345 | Transmission - Rearend | 0 | 07-16-2007 09:23 PM |
| 12 bolt posi rear end fluid | 1972bigblockchev | Transmission - Rearend | 3 | 06-19-2007 09:46 AM |
| Transfer case - NP 203 - 205 | jrm123180 | Transmission - Rearend | 2 | 03-24-2006 07:36 AM |
| 12 bolt posi | 72chev355 | Transmission - Rearend | 1 | 11-27-2003 09:21 PM |
| just swapped to a 12 bolt and the yolk is wrong! | Destructo | Transmission - Rearend | 6 | 10-14-2003 08:54 PM |
