Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 07-04-2008, 08:34 AM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
12-Bolt Posi
I picked up a '66 12-bolt, 3.31, posi unit for my '67 and disassembled it as far as my limited rear end expertise allows, i.e. axles and the carrier are out. It's an Eaton unit and I have to assume it needs rebuild.
Having never tackled these before, does anyone have a step-by-step guide for the "knowledge-impaired technician". Also, what do I look for in terms of bad posi parts?
Thanks.
Old 07-04-2008, 08:42 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: 12-Bolt Posi
Thanks.
I've never had an Eaton unit apart... no help there.
I moved your duplicate post to the dump.
If you can't fix it with a hammer, you have an electrical problem.
Old 07-04-2008, 02:22 PM
MI2600's Avatar
Member# 3287
re: 12-Bolt Posi
Oops. My bad.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "12-Bolt Posi"
12 bolt posi id CHEVELLE12345 Transmission - Rearend 0 07-16-2007 08:23 PM
12 bolt posi rear end fluid 1972bigblockchev Transmission - Rearend 3 06-19-2007 08:46 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 06:36 AM
12 bolt posi 72chev355 Transmission - Rearend 1 11-27-2003 08:21 PM
just swapped to a 12 bolt and the yolk is wrong! Destructo Transmission - Rearend 6 10-14-2003 07:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
