12-Bolt Posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2008, 09:34 AM
MI2600's Avatar
Member# 3287
12-Bolt Posi
I picked up a '66 12-bolt, 3.31, posi unit for my '67 and disassembled it as far as my limited rear end expertise allows, i.e. axles and the carrier are out. It's an Eaton unit and I have to assume it needs rebuild.
Having never tackled these before, does anyone have a step-by-step guide for the "knowledge-impaired technician". Also, what do I look for in terms of bad posi parts?
Thanks.
Old 07-04-2008, 09:42 AM
Crosley's Avatar
Wiki Edits: 1659
Thanks.
I've never had an Eaton unit apart... no help there.
I moved your duplicate post to the dump.
Old 07-04-2008, 03:22 PM
MI2600's Avatar
Member# 3287
Oops. My bad.
12 bolt posi id CHEVELLE12345 Transmission - Rearend 0 07-16-2007 09:23 PM
12 bolt posi rear end fluid 1972bigblockchev Transmission - Rearend 3 06-19-2007 09:46 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
12 bolt posi 72chev355 Transmission - Rearend 1 11-27-2003 09:21 PM
just swapped to a 12 bolt and the yolk is wrong! Destructo Transmission - Rearend 6 10-14-2003 08:54 PM
