Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 11-27-2003, 08:06 PM
72chev355 72chev355 is offline
12 bolt posi
I have a 72 chevelle with 355 10 to 1 compression, ported polished, holley 650 double pumper, lunati .515 cam, double hump heads, 2.02 valves, roller rockers, headers, edelbrock victor jr., flowmasters with 350 and 3500 stall, with the 8.5 10 bolt with 3.08 gears, i want to upgrade to a 12 bolt posi with 3.73 gears, i want to know what kind of performance gains i would get, first gear now is violent it will put you in the seat, second is seems weaker, and so does third, can i expect for the higher gears to make the car pull through all gears?
Old 11-27-2003, 09:21 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: 12 bolt posi
After the gear change you will notice the rear tires will go up in smoke in low gear and you will pull much better thru the upper gears. Also engine braking on decel will be more evident.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
