12 bolt rear end id help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 06:15 PM
this 12 bolt chevy rear end i got has CHC 040E stamped on the right axle tube and embosed on the housing 3969278nf and b41 any help would be great thanks
Old 01-02-2006, 09:52 PM
73oldsman's Avatar
Here's a site that may help...http://www.chevellestuff.com/generic/axlecodes.htm, which says the 3969278NF housing was used in the 1970-72 Chevelle and the axle ID's as a Positraction (2.73) 040 = day of the year produced starting w/Jan 1st(040 day), I think. Hope this helps...
Old 01-03-2006, 05:50 PM
id help
thanks for the help 73oldsman
Old 01-03-2006, 06:38 PM
73oldsman's Avatar
Your welcome
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
10 bolt rear end question 8.2 or 8.5 ?? nheron Transmission - Rearend 6 03-02-2008 08:16 PM
New 12 bolt Rear/ questions. RObs71Nova Transmission - Rearend 1 12-27-2004 07:19 AM
Question about 12 bolt rear end Roy_67_SS350 Transmission - Rearend 6 12-14-2003 11:57 AM
