12 bolt rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2004, 11:22 AM
New Member
12 bolt rebuild
i currently have a 12 bolt rear end in my chevelle. I have the eaton series 3 carrier and a set of 4.11 gears along with a new set of axles and bearings also. This will be my first time rebuilding a rear end, and would like to know if any of you guys got tips/tricks to make my life easier rebuilding this.
thanks
Old 09-05-2004, 11:38 AM
fourbyfourblazer's Avatar
Chopper Builder o<>\o
Last journal entry: Dash Removal
I was going to rebuild the 12 bolt on my blazer but decided on having Hoopers Rearend in Sun Valley, Ca., do the work since they only charged $100 for setup. You have to put the right shims in and set it up perfect otherwise you get vibration and wasted your money and time.
Old 09-05-2004, 11:48 AM
New Member
so it was only $100 to put it together?
Old 09-05-2004, 01:01 PM
yes. I bought the ring and pinion and the bearing kit from an off road center and then took the whole axle to the rear end shop and it was $100 setup. They charged me $35 extra for new outer bearings. That was it. They said it would have been a $100 more if they had to take the axle out of my blazer.
Old 09-06-2004, 11:22 PM
Are the gears made for a 3-series carrier?
Old 09-07-2004, 09:23 PM
New Member
yea, the gears are for a 3 series carrier. if i can remember i think they were an extra 50 buckx for a 3 series. what is the difference between a 3 series 4.11 and a 4 series 4.11 ring and pinion?
Old 09-08-2004, 10:40 PM
The 3-series ring gear is thicker, because the mounting flange on the 3-series carrier is farther to the left.
