12 bolt spider gears binding
Long story short, I need to replace the spider gears in my open diff '64 truck 12 bolt because I am converting from 17 spline to 30 spline axles. I bought a kit made by Superior that includes both side gears, spider gears, and thrust washers to go behind each gear. However, when I have it all installed in the carrier, the gears are virtually binding against each other. If I stick an axle in and try to turn the diff, it takes some effort and the gears are very notchy because there is zero play between them. Its like the thrust washers are too thick, especially the conical ones behind the spider gears. Without them in place however, the gears seem too loose.
I should note that the original spider gears did NOT have thrust washers behind them, but the side gears did. Now I'm pretty confident this 12 bolt hadn't been abused. The whole truck is in good shape, and everything looked really good when I opened up the diff. The main ring & pinion backlash is perfect, the teeth on everything looked perfect, etc etc. So I don't think the carrier is warped or anything like that. Anybody have any ideas about this? How are the spider gears supposed to feel? What kind of play is acceptable? |
Thats good advice..and now that you have some knowledge now,I would still call Superior and talk with them about this,and hopefully be able to get your money back if it doesn't work out.
Thanks guys for the advice!
I just called Superior and they said that it is good that the gears are tight. The guy said its better they be too tight than too loose. Does this sound right to you guys? |
Tights good, loose is bad !! You installed new spiders & shims they need to be broke in, drive till hot, let cool , drive till hot let cool again, Do this several times and the gears will break in with a good pattern!
Jester |
| 8.5 10 bolt spider gears | Hubes | Transmission - Rearend | 1 | 07-02-2008 04:38 PM |
| Welding up spider gears | Pac-Man | Transmission - Rearend | 4 | 02-11-2006 01:53 AM |
| 8.5" spider gears | onecoomofo | Transmission - Rearend | 5 | 06-14-2004 07:41 AM |
| Exploded spider gears...? (12 bolt GM) | Bumpstick | Transmission - Rearend | 7 | 10-07-2003 06:00 PM |
| 12 bolt spider gears question | 85406 | Transmission - Rearend | 2 | 11-28-2002 04:59 PM |
