12 bolt truck build? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2013, 02:23 AM
Hi guys im new to the forum I was just wondering how challenging it is build a 12 bolt truck rear end I have a full spool c clip elemanators and moser axles with some 4.56 gears also what tools will I need a have a dail indicator and torque wrench ect thanks guys
Old 06-06-2013, 07:09 AM
big gear head's Avatar
High Performance Rear Ends
The truck 12 bolt is no easier or harder than any other rear end. Setting the pinion depth, bearing preload and backlash are the critical things, as always. The 12 bolt uses shims for pinion depth and backlash, so you will need a micrometer to measure shim thickness. You will need a dial indicator with a magnetic base for measuring backlash. You will need a small dial or beam type torque wrench with a range of 0 to 30 inch pounds to measure bearing preload. You will need a press and a bearing seperator for pressing bearings on and off. You will need to know how to read the contact pattern so that you will know what adjustments need to be made to the pinion depth and backlash.
Welcome. You will find a lot of usefull information here. Please use periods and capital letters so us older guys can read what you are writing.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (06-06-2013)
Old 06-06-2013, 02:25 PM
Yes I have found this forum to be very usefull. Thanks for the reply.
350 two bolt build blackbird65 Engine 14 08-09-2012 09:54 PM
383 build question (new 4 bolt or machine my 2 bolt) chucksrt Hotrodding Basics 18 12-21-2010 12:17 AM
Build a 10 bolt or 12 bolt for 450 HP ?? Blownchevelle68 Transmission - Rearend 7 05-11-2010 09:34 PM
8.2 10 bolt build 65 el camino defilade Transmission - Rearend 4 06-06-2009 12:42 PM
8.2 ten bolt build oregon chevelle Transmission - Rearend 7 02-13-2007 10:22 PM
