12 bolt truck rear end puzzle - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2006, 05:01 PM
MiMAX's Avatar
How do you count splines on axles? The ones in this 12 bolt truck rearend (3896839) (shortened with a spool aka 513 gears) has just 17 splines and 17 gruves. So what posi unit would fit. Most advertize 28,31 or 33 spline.
Can someone explain the spline count to me. Cannot find any type of axle spline like this ,if this is correct. I even wrapped it with paper then rubbed it with a pencil so to get accurate count. I have counted spline on 4 speeds. Cannot figure out what to do. This is on my latest project car. VW beetle 327/turbo400/forty ford nose/Straight axle,disc all round. I just do not care for a spool. Thanks MiMax
Old 12-27-2006, 07:12 PM
oldmanchopper
Last journal entry: Update
get a book called chevrolet by the numbers and it shows all the combos. Take the numbers and divide such as 16-41 41divided by 16 = 2:56 good luck
Old 12-28-2006, 12:11 PM
To count spinles, you simply count the number of high parts(splines) or the axles. 17 splines doesnt sound correct at all for any axle I have heard of.
there is NO math needed whatsoever.
The math is used for calculating gear ratios.
peace
Hog
Old 12-28-2006, 04:36 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The H072 has 17 spline axles. To my knowledge, the last year they were installed under a GM pickup was in 1971 on the 3/4 ton and higher rated pickups/trucks. It's ancient and was used for years, dating back to the mid-late 40s if I remember correctly. It was full floating axle with 8 lug hubs. It had both a removable rear cover and dropout center section. It's very distinct looking. If you have this, or something similar to it, you're probably going to have a hard time finding parts for it and it's going to be expensive. I priced a ring and pinion for one a couple years ago and it was $430. You could call Randy's Ring and Pinion in Seattle, WA and they could help you solve your question. www.ring-pinion.com
My 72 Blazer has a good 'ol 12 bolt and it has 30 spline axles. What year truck did the axle come from? If this is a 12 bolt then somebody, for whatever reason, may have cut a funky spline into it.
Old 12-29-2006, 12:46 PM
Wow, a 17 spline axle ehh?? Do you have any idea on how strong those axles are??
peace
Hog
Old 12-29-2006, 12:58 PM
Blazin72's Avatar
Wiki Edits: 19
Nope no idea. It was used for about 25 years though. It's ancient by todays standards. They also have a ~12 1/4" ring gear.
Here are some various pictures of H072s and H052s I found on Google... http://s14.photobucket.com/albums/a3.../Eaton%20H072/
Old 12-29-2006, 01:05 PM
Thanks man.
peace
Hog
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 12:51 AM
71 chevy truck rear end choppy71 Transmission - Rearend 14 09-23-2005 01:55 PM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-28-2004 11:41 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
